Catch can findings
cody mummert
Pa
I have dumped my can a few times now and every time it is full of a milky tan thick mess I'm guessing its coolant and oil any thoughts?
Wiggleroom
could be a headgasket leak or condensation in the engine ?
could try running marvel mystery oil or similar additive and see if its still happening
any pictures?
R.L.K.
Bristol , Tn.
Myself and others have experienced this mainly during cold weather , I believe it to be extra ( normal ) condensation build up during the cooler winter months .
If your not getting your engine oil up to 212°f and higher for extended times during the winter ( and most of us do not ) there will be more water/ condensation in the oil . Due to it not being burned off .
Luckily you have an OCC preventing this CRUD from entering your intake plenum where Two things should be :
1 Clean Filtered Gasoline
2 Clean Filtered AIR .
Hope this helps [emoji1303]
cody mummert
cody mummert
Pa
Thanks I was also thinking head gasket I still have power train warranty left but not much just didnt want to miss out on using it if needed
JB1
Houston, Texas
Got a pic of it?
If it’s just a little it’s probably condensation
R.L.K.
Bristol , Tn.
A member here @Hemi395 I believe was the one his looked like coffee with cream , and his next OCC dump was normal oil color I believe [emoji848]
This pic is one of mine with milky crud in the bottom during the winter...738ddd0894c74899c10f89da157f582b.jpg
Ramnewbie
Yep, I experienced the same thing. I had installed my CC in the spring so all summer into fall everything looked good. The first time I dumped it during cold weather I was worried until you guys assured me that it was normal. Guess what, as soon as it warmed up last spring everything back to normal again.[emoji106][emoji106]
Sent from my VS996 using Tapatalk
JB1
Houston, Texas
If it was a blown head gasket you would have other issues as well
joshuaeb09
Medina County, TX
Its the fact aluminum has a fairly good thermal transfer ability combined with cold ambient temps. Really sucks the moisture down into the can. If you were to be able to run a camera inside the can you would likely see sweating on the walls until the can finally heats up from being close to the engine.
William Hastings
Aston, PA
My dump last week looked just like this. Previous dump in the summer was just dark oil.
Hemi395
Cape Cod MA
Every winter mine looks like that. It's due to the condensation from the extreme temperature change from the cold ambient temperature to the operating temp of the engine. Just think, your engine would be eating that if it weren't for the catch can...
newls1
GA
mine looks the same as stated in that picture as well, and during the summer, its just oil... so i guess this is all normal. What a great mod this OCC is, really cant believe our engines would be burning this crap other wise!
