catch can wtf
jwheeler
Washington
Show us how you have it hooked up.
crazy_luck
Minnesota
is whats in the vid not enough ? if not I can go snap a pic real quick
Need to see where both ends of the rubber hoses connect, to make sure its hooked up correctly - can't see the other ends with the engine cover on...
jwheeler
Washington
Yeah, I'd like to see where the other ends go. Have you opened it and taken a look inside it just going off the indicator on the side? My truck has a lot more miles on it but I get several ounces at every oil change.
Open the can up and lets see a pic of the inside of it to, along with a pic of where it's hooked up to,and did you use heater hose to plumb it,that's a no-no,heater hose collasps under vaccumn
1500ram12
5.9L Cummins
This is how it should look
Sent from my SM-N910V using Tapatalk
H
hemi_hawk
what I did was like you did but my hoses cross and go into the nipples furthest from them if that makes sense
doz
What can do you have?
Swap the hoses around could be backwards?
MADDOG
Living in a Firepit
Yeah, I'd like to see a pic of what's hooked up to what and what kind of hose you used.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
No way a functional catch can wouldn't have any oil in it after a couple thousand miles. There is either a problem with your can, hoses, or where you have them hooked up.
Time to take it apart to inspect the inside of the can and confirm that the hoses are connected properly.
H
hemi_hawk
as far as hose goes, idk what hose I use, I cannot remember, what hose should I get if I have the wrong stuff ? can I get it at auto zone ?
crazy_luck
Minnesota
Use rubber fuel line hose. It is internally reinforced which will prevent the hose from collapsing under pressure/vacuum. And yes, you could get it at auto zone.
THETANK
up jor *** mang
2015 R/T
strange but true story I swear. When driving in the city my cc would catch the normal (if that's possible) amount of blow by??? On a 6500 mile trip I opened it to find it had zero product, back to city driving afterwards and it collected as usual. Beats me.
H
hemi_hawk
Just drove from tampa florida to erie,pa and its bone dry
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
You either have it installed wrong, or there is something inside the can that is blocking airflow. It is not physically possible for that can to be bone dry after that many miles.
H
hemi_hawk
Ill upload a pic and uninstall and chack it this evening
misuracaf10
You have a perfectly efficient engine [emoji23][emoji23]
