Center console swap
Ram-bo69
I’m doing a center console swap in my 2014 1500 and I’m wondering if this is the cutout to route ducting for rear ac? If so, what’s a good way to remove the cutout? Thank you!
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Soldering iron with a chisel/blade tip. Razor knife works too (especially if you get it hot).
Atcer2018
Virginia
+1 on the multi tool. A soldering iron works too but you still need to clean up the little globs of plastic with a razor knife. If you don’t have a multi tool Harbor Freight sells a cheap Chinese made electric corded model for about 12 bucks on sale and they are almost always on sale. It works well for the occasional use DIYer.
Question about the picture.
Was it taken from the seat looking forward towards the engine compartment
If so, the thing that i think that i see is the
2 HVAC Actuators for the #1 & #2 Mode Doors
This is a GEN #3 HVAC
It is basically the same as a GEN #4 unit
Watch the first 4 or 5 minutes of this video.
After you do, you will know more than 1/2 the people on this site, mostly about the Door Names
It even shows where the Rear Cab vent would be located
This would be the tube that carries the Heat & A/C to the rear of the full floor console
the part on the rear of the console
the 2009 Dodge ram 1500 air came out at the bottom sides of the console image above
