Zoe Saldana
My understanding is that the 2500 6.4L has an internal PCV or something - that can not be changed. I just looked on my 6.4L and I don't see one.I'd wager a new PCV valve had the major impact. We experienced major losses of power on engines with restricted PCV's at work (these from icing in adverse weather test conditions).
Engine Masters ran dyno tests on all types of spark plugs, worn, new, etc., and saw little difference in output. In other words, unless the combustible mixture isn't burning thoroughly, there's not much difference. So why change spark plugs? Because we don't know exactly when they will become that worn. That's why we change at different intervals to see when the electrodes start to erode and arc-flash over. But it may become more difficult to pull the wiring boot and unscrew the plug if we wait too long. I had a helluva time pulling plug boots on my big block Chevy in my motorhome. Plugs were too close to the exhaust manifold and got thermally welded to the boots!
My experience has been 30 k miles for nickel coating, 50k miles for platinum coating, 100k miles for iridium coating, who-knows-what for ruthenium coating.
Is there a PCV that can be changed? If so where is it?
Thanks
