Check engine light problems
Statcher1
Kentucky
Alright guys about a month ago I had my JBA Longtubes installed. And ever since then I have been getting a P0133 engine light. Last week I replaced the O2 sensor that was showing the code. No dice. It still thrower the code. So I know that's not the problem. Today I re torqued the header bolts down thinking they loosened up some and was allowing a exhaust leak. And I'm still getting the code. Do any of you guys know what my problem is. And how to solve it. This is driving me crazy guys. I'm in desperate need of help.
Statcher1
Statcher1
Kentucky
Yeah I cleared it with the tuner. It didn't come back. But it was logged in the tuner. So it was getting ready to set the light off.
smurfs_of_war
Swift Current, Saskatchewan
Ok here's a stupid question: did the longtube headers move the position of the sensor further back?
Sent from my SM-G925W8 using Tapatalk
Statcher1
Statcher1
Kentucky
Shoot I'm honestly not sure if it did or not. I'll have to crawl under my uncles Limited and compare his to mine.
Statcher1
Statcher1
Kentucky
It could possibly be farther back. The code P0133 is Oxygen Sensor Circuit Slow Response (Bank 1, Sensor 1).
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
I'm posting from my phone, so I can't see your sig. If you have custom tuning, simply have your tuner disable the code. We see this a lot on the newer trucks with longtubes, regardless of whether you have cats or not.
Statcher1
Statcher1
Kentucky
Hey Matt I was hoping you would chime in. The code that it's throwing is not for the cats. It's throwing a code for I believe the sensor in front of the drivers side cat location.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
From what I have seen, it's caused by the increased airflow of the longtubes though. I have seen this code thrown by guys with all brands of longtubes...arh, jba, and stainless works. It isn't hurting anything though as we simply clear the code in the tuning and the trucks run just as well.
Statcher1
Statcher1
Kentucky
Ok. So this is a code that can be cleared through a hemifever tune? Looks like I'll be selling my Bullydog to a boy at work then. Because this is driving me crazy.
joshhhh
