Check engine light
Hootbro
U.S. Army Veteran
Army
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
.......... Also it spit out a C3F03 code, what's that?
"C" codes are usually a chassis codes but will usually follow all numbers after the "C".
C3F03 is a classic hexadecimal code that converts to a 16 bit binary code of "1100 0011 1111 0000 0011". If I was to guess, that is a code only for use at an engineering level to be decoded by a source control document and not meant for end user interpretation.
Did you have a check engine light when you got this code? If not, might have just been part of a pending code that was waiting for another event trigger to post the check engine light.
S
SilverRam11
4.7 V8
Yes the check engine light has been on. It stopped telling me the gas cap was off after my last fill up I made sure to tighten the gas cap. Check engine light is still on.
powderbrad
Edmonton, AB
FYI...
I had p0300 codes after installing a 87 mmTB. No idea why. Tossed stock back on no codes. 87 on, instant misfire codes and rough start idle and rubbing.
Matt was awesome enough to send me another. No problem since.
I checked for leaks in vacuum, air intake, tuning, exhaust. Didn't figure it would be a TB problem.
S
SilverRam11
4.7 V8
I picked up a new fuel cap at the stealership to see if that gets rid of the EVAP code. Then I can get back to seeing if the misfire shows up again. Is there anything hard about swapping coils? I'm going to attempt to swap two myself now that I have a scan tool to track the code.
PCT
2019 2500 6.4
Northern California
Nope, take you 10 min!
joshhhh
