PT-4
- Apr 6, 2020
- 117
- 84
- Location
- Western Wisconsin
- 2014
- 5.7 Hemi
Still haven't found a YouTube video on this.
I'm gonna go out on a limb here,and say if you need a video to torque the intake bolts,you probably shouldn't be working on your truck.Just my 02 though. Red posted the torque sequence,and i gave you the size of socket you needed,plus gave you a good tip of where the bolts are ,it's up to you to go look at the manifold from there.Still haven't found a YouTube video on this.
Very little I can do anymore. Don’t have the skills or correct diagnostic tools. That being said, I can torque bolts if needed. Lol again thanks for the advice and diagram for proper sequence.I'm gonna go out on a limb here,and say if you need a video to torque the intake bolts,you probably shouldn't be working on your truck.Just my 02 though. Red posted the torque sequence,and i gave you the size of socket you needed,plus gave you a good tip of where the bolts are ,it's up to you to go look at the manifold from there.
Sorry to be the heterodox again, but while the theory is good I'm not so sure the expansion/contraction of the intake manifold is causing the intake bolts to turn (loosen).
The gasket used in this application is a elastic rubber-like compound O-ring. Over time they lose some of their elasticity due to heat. This results in loss of elastic pressure with resulting loss of force against any two components being sealed. Like a lot of intake manifolds these days, new ones almost always come with new O-ring seals.
I've asked techs if they've ever found an intake seal that cause a problem on a Hemi, and the answer has always been "no". Of course, it doesn't mean it can't happen. But I suspect periodic retightening is only bringing the intake surface closer to the cylinder head and eventually the intake surface will be in full contact with the head. This could cause the intake to crack.
Regards,
Dusty
2019 Ram 1500 Billet Silver Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 3 June 2018. Now at 82990 miles
