Clearing Tire Pressure Alert From Dash
P.Lavers
Hey guys, so when I installed my HID kits for my headlights and fogs at first I didn't have the cancellers. So when I first installed them fired up the truck it tripped the tire pressure sensors. I have since gotten new wheels and tires so the sensors are fine I just want to clear the light off my dash. Any idea how to do that without going to the dealership and paying 130 an hour? Thanks guys! :favorites13:
mohemipar
2017 Laramie
6.4 Hemi, 4.10's
My warning always just resets on it's own after about 10 mins of driving, but my truck is stock. Don't know if that matters.
lmeavtitn
Omaha NE
2015 Ram Rebel
So you still have your factory sensors in your wheels? Ram trucks reset after the air psi adjusted. Sometimes it takes a little bit of driving but not much. When you look at your EVIC screen that displays your tire PSi does it say "---" or does it have a PSI number on the wheels positions.
P
P.Lavers
Yes it shows "--" on each tire, no it has been like that for like 6 plus months and hasn't reset yet.
P
P.Lavers
Did I fry something when I put in the HID the first time without the canceler?
mohemipar
2017 Laramie
6.4 Hemi, 4.10's
I had a Cadillac where if the auto reset failed, you could use a strong magnet to hard reset the factory sensors by holding it up to the stem. The horn would chirp after each reset. You just had to do it in the order corresponding to the DIC.
