Clunking noise
Pasteris71
Wilbraham, MA
I recently installed a 2.25" leveling kit in my 2012 Ram 1500. There was no noise before the install. Shortly after I noticed that every time I drive over small bumps or uneven parts in the road I'm hearing what I can only explain as a clunking noise. It's coming from the front end. I went underneath and checked sway bar, tie rods and all looks good. Anyone else have this??
P
Pasteris71
Wilbraham, MA
Sway bar links
After baking in the 96 degree sun today, along with some few choice words, I found the clunk noise coming from my sway bar links. Easy enough fix! Once it cools down its time to fix them.
vtaylor
2013 Sport
I just had this same issue. I still have the Mopar warranty though so I took it in to the dealer. They said it was the shock making that noise, replaced it under warranty.
P
Pasteris71
Wilbraham, MA
Well the links didn't fix the problem. Still have the clunking noise. Everything is tight. Thinking it may be time to get rid of leveling kit and get some Bilsteins.
P
Pasteris71
Wilbraham, MA
Found problem
Upper ball joints. Just enough movement to make the clunking sound. Of course they are not greasable so I'm going to replace with new Moog greasable ball joints.
noraa73
