Cob U shaped LED
R.L.K.
Bristol , Tn.
Check with J J Retroshop
charonblk07
Calgary, Ab
F1-A forged 349ci
Wow those are amazing... do want. Wonder how hard the install is...
Aside from opening the headlights these, quite literally, just stick on and you wire them in how you'd like them to run. They can be your DRL, just a turn signal, or there's the RGB with switchback option so you can have a multi-color angel eye with an over riding turn signal. It gets as complicated as you want it to be but it's dead simple to install.
Limeybastard
Limeybastard
Shady Hills, Rednecksville Boro, Florida.
Looks good, but not what I was talking about. The link you posted seems to show a tiny U shaped light bar that works on the Mopar projector headlight assemblies.
I was talking about a larger U bar that would sit sideways inside the stock rubbish Quad headlights, similar to below.
BlownGP
Houston/Baton Rouge
I wanted to get some straight ones to put under my headlights but I didn't like how they looked when off.
charonblk07
Calgary, Ab
F1-A forged 349ci
Is this what you mean?
Or do want one end open?
I get what you mean. The only COB U-shaped LEDs that are prefab'd for the Dodges are the small ones for the '13+ projector housing to go over the high beams. You can get a SMD based halo ring for the entire quad housing as JGB showed in either a switchback or RGB but that's the only option in pre-fab'd pieces. You can make your own if you want but it's not as clean by using flexible strips in switchback or RGB
Limeybastard
Limeybastard
Fair enough, thanks.
Sent from my SM-N910T using Tapatalk
