Code after Dual Battery set up
ramhunter9
ramhunter9
P-Star Jeep Wrangler
oh I will and my load tester is a POS ..
I ended up just turning everything on and using the good ol volt meeter .
weedahoe
Banned
South GA
cammed and custom tuned 5.7
My thoughts, from out last talk and thread, with this isolator, is the alt wire going directly to the isolator or to the PDC?
If you have issues again, reroute the alt wire back to the PDC post and disregard the isolator and other battery for now and see it that works.
LMK.
ramhunter9
ramhunter9
Line Directly from the alt to the isolator .
Battery one is ran from the isolator to the fuse box to the battery post positive
Battery two is ran from the isolator to the battery post positive
RubberFrog
I wonder if the isolator occasionally shuts off juice to battery 1? That would cause the pcm to see no voltage and throw the code. I would contact the manufacturer and find out if it does that.
ramhunter9
ramhunter9
does this all look right???
most of all what should a battery hold at when the truck does not run ?
These numbers might be off a tad .. cant member lol .. watch the video
14.6 v both batterys RUNNING
12.6 v both batterys NOT RUNNING
Running from the ALT 15.7 v RUNNING
Running form the Alt .3v NOT RUNNING
mY GENERATOR CODE CAME BACK but I think thats because I left my CB on and it is 100w .
If I cant get this im getting rid of the isolator and just jumping the batterys . Oh and
Called Dodge they said my truck does not have a condenser fan relay it is a dummy code .. so thats good . So that leaves me to the generator code .. just want to make sure this is all correct in the readings
After watching this .... should I just run a seperate line to the battery from the isolator ?
As it is now it is running to the fuse box and Battery
RubberFrog
Your numbers look good. Have you called the manufacturer to see if there is a possibility it shuts off juice to bat #1?
ramhunter9
ramhunter9
They dont know . It does not shut off the juice to batt 1 because it is reading over 14v when running
with the truck now running .. volts are equal on each bat , so the ALT is working and the isolator is passing current like should
Now with the truck off battery 2 that has all the acc on it reads 13v
Battery 1 reads 12v
ramhunter9
ramhunter9
what is a non running truck battery supposed to hold at ? when off
RubberFrog
From what I read on their website (not very technical unfortunately), it seems the isolator can turn the current on/off to each leg. If it is shutting it off to bat 1, this may be causing the problem. You maybe better off going to a large solenoid/relay.
ramhunter9
ramhunter9
Like what George ?
ramhunter9
ramhunter9
How is that different ? And I would need 2 ? Where does the ALT hook into that ?
RubberFrog
You don't mess with your alt with that set up. Ypu run a wire off bat 1 to a large terminal on the relay. The other large terminal connects to bat 2. Run a wire from a key on source (cig lighter works good) to a small terminal. Run a ground to the other small terminal. The relay is only energized when the key is on, so the batteries remain seperate until the key is on.
ramhunter9
ramhunter9
im done with this , all is fine im going to guess the batterys should stay at 12 volts when not running and over 13v running .
Thanks
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Turned off, the battery should be 12.8 on a fully charged battery. Charging can read as high as 14.5, more than that I start thinking it is overcharging. The isolator I would guess is causing the problem, the isolator George is discribing sounds like it would work better.
ramhunter9
ramhunter9
I was not going to run a isolator at first , then was instructed to so I did . Now Im instructed to get another one . Screw that .. going back to running them like I had them .
Im not the smartest guy , but im not going to keep buying band aids for this . I will take it to the dealer and trade it in if this **** keeps up .
Hammer_Z71
That's the only way I knew how to do it. As a matter of fact, I said that in the original thread.
http://www.ramforum.com/f45/dual-battery-setup-4898/
I wonder if you HAVE to run that one that is marked ALT to the alternator on the one you bought? Might try to run it the way George and I mentioned and see how goes...
Redtruck-VA
Virginia
Try not to get frustrated Dave, just think if you had a 03 you would have to lock up all your guns... They are really wacked!
ramhunter9
ramhunter9
both batterys are stable at 12.5 v not running and running over 14 v
The isolator is working . We will see
