Cold Front Grill Block
WhiteExpress
Midland, TX
Well, as the temperatures plummet and my bordem increases, things happen.
I've always played around with the though of a 'grill block' to help with my brick like aerodynamics.
And with it getting colder, I figured, Hey, the truck should heat up faster too.
So, I bought a piece of chloroplast (plastic cardboard) which seems to be the chosen material for such creations.
Made a quick template from cardboard and transferred it over to the chloroplast.
Marked some places to zip tie it from the back side and drilled out holes.
Zip tied it on and re-installed the grill.
I know around town I'll have 0 issues, I'll be actively monitoring the coolant temps to see if it's getting to warm etc.
My thoughts, with that clutch fan, it'll put more than enough air through it indefinitely.
Here's the pictures:
In the beginning, one dirty grill:
Templates made, and transfered to Chloroplast:
A few holes and zip ties later, should be alright at highway speeds...
Semi-close up of the upper block:
And a close up of the zip ties, they fit near perfectly in the factory mesh insert:
And installed back on the truck. The top is fully blocked, and the bottom I left open the width of the radiator (covering reservoirs won't hurt a damned thing):
I'm quite happy with how it came out.
Will it offer any huge benefits, hard telling...
Was I bored and this took up my afternoon... Indeed! :Caffeine:
I think unless you were looking at it, you'd never have a clue what's going on either.
White Beauty
Moncton, NB
2011 Ram 1500 SLT
looks 10000000 times better then this!! (see pic attached)
this looks interesting.. hidden behind the grill... Clicky
Alfonsio
2010 Big Horn Quad Cab 4x4
Nice job!
WhiteExpress
WhiteExpress
Midland, TX
I was VERY unimpressed with the Mopar offering. The one from Geno's is cool from the radiator block stand point, but I also wanted to try and improve my MPGs a touch.
Thanks for the positive responses!
WhiteExpress
WhiteExpress
Midland, TX
Trup, I thought about a total block, and honestly, since my truck never gets 'stressed' by any means, I'm sure the clutch could pull plenty of air through the radiator w/o any issue.
But I didn't want to have to pull over somewhere and try to cut zip ties n such to get the truck from overheating.
craigsez
Novascotia,Canada
I dont think its gonna help mpg unless you drive 80 mph all the time and to that i would say slow down..
Looks good an all but...
WhiteExpress
WhiteExpress
Midland, TX
I hear ya, but I actually do about 50-60% of my miles at 60-70 MPH, so slight aerodynamic increases could help this lumbering beast a bit. As I said, I'm not expecting anything, just something to do. If it works, Great!
