Confused about offset...
Cloviz
Ok I know how offset works and everything but some sites only say high or low offset. Can someone explain that to me? How low is low?
Cloviz
Cloviz
So from what I'm understanding "low" offset is anywhere from 0 to +20? I want this set of wheels in a -24 but it's labled as low offset. Dumb site doesn't tell me squat. Not getting my business then
tbridg00
Arkansas
As far as exactly what offset they are referring to you would probably have to contact them or try to find the wheel on another site that offers better information on exactly what the offset is.
RamWrayzor
Sin City, NV
With a -24 offset, you wheels will stick out from the wheel wells to give it that aggressive off road stance. Negative offset takes away from the vehicle, hence making them stick out past the fenders. Positive offset adds to the vehicle, hence stuffs them more into the wheel wells. Most with 4x4 go with -12 or more to stuff meaty tires under the truck and have the nice wider stance.
Fubar65
Hesperia, CA
2015 Ram Express
Will a - 12 offset on 18x9 rims with 295/65/18 duratrac fit a 2015 express 2wd on stock height.
xrsman
Ontario
3.0 Ecodiesel
If I'm correct that's a 35" tall tire. No that probably won't fit without a leveling kit. If it did end up fitting it wouldn't look good without a leveling kit IMO. Even with a leveling kit 35's are too big IMO.
Cloviz
Cloviz
I'm lifted and leveled, I know what offsets are I just wanted to know the numerical value of the "low" value the site says
Fubar65
Hesperia, CA
2015 Ram Express
It should be a 33 x 11.6 according to the metric tire conversion
xrsman
Ontario
3.0 Ecodiesel
Stupid me for some reason I was thinking 20" wheels lol! Yes on the 18" wheel it is only a 33
Fubar65
Hesperia, CA
2015 Ram Express
Lol think it'll fit? Also I can downsize from the stock 20 inch rims to 18 correct? One site I was looking at said I can't downsize from the stock 20
xrsman
Ontario
3.0 Ecodiesel
Lol yep it will fit because height wise it's the same as stock. You can downside to 18's no problem
NorthTexasHemi
DFW Texas
2014 RAM 1500 Lone Star
you need to be concerned with the overall diameter and width so it will fit everything else is how you want it to look :)
