Console swap
NorCal
Thanks to everyone for all the info on what to do to complete the swap.
It's not a bad swap for dyi, even if you make your own bracket to hold it down. Not quite done, but I wanted to quit thread jacking.....does anyone have a pn for the rubber piece that covers up where the radio bezel and console come together? And is the console considered "gray?" Because I'm trying to order the kick panels for the console and the options are beige and gray.
Copatlarge
that is bad ass looking!! didn't think that was possible... what would a mod like that run?
The Crow 1994
Nebraska
Hemi 5.7L w/8 Speed Trans.
The panels you need are grey. Otherwise the interiors with the Canyon Brown are mated with the beige panels.
2014StormTrooper
Aggieland, TX
2014 Ram 2500 Longhorn 4x4 2003 LY Evo VIII ER Built 2.2L
6.7 CTD / 4G63
I did this swap too in my Laramie, wasn't too bad
07silverbullet
NorCal
Thanks. So far I'm into it just shy of $500 I think it'll be just under 700 after I get the kick panel pieces and shifter cable to make the floor shifter.
nyciti
Look in the DIY section I posted a how to and cover all of the part numbers too.
Kwajguy
Best bet would be to find someone that wanted the jump seat and do the swap. It was real straight forward, we did ours in an autozone parking lot. I had a console, just need to look at the little things like rear AC and color. For me, had to reroute the console cable under the carpet, then find two connectors that were taped up behind the dash. Make sure you get everything and take a couple pics.
