Control arms
Jimmy68
Lethbridge Alberta Canada
5.2L Magnum
Ok. I have an 01 1500 4x4.
I have the level block up front. I'd like more and what I see is if I get 2500 coils I get 2" more.
Which is 4". Now the control arms and track bar need to be longer.
How much longer?
Of course I'll need a pitman arm and shocks.
Arms and the bar can be built. But I need to know length and I'll make them adjustable for fine tuning.
Merc225hp
NA
truck
gas
What diff are you going to be using the hp 60 or the 44? Track bar length is relative to the bracket on the frame what's your plans there?
Merc225hp
NA
truck
gas
Give or take 17.5 upper and 19 for the lower c to c.
Merc225hp
NA
truck
gas
Nice.
Thanks man.
Track bar?
I'll use some heims if i do this. Be sweet.
So much to do first.
I can post up all kinds of numbers for the track bar. What's your plans for the frame end of things.
Heims on the control arms ping like a sob, ok for one end but a bushing is better for one end of the arms.
Jimmy68
Jimmy68
5.2L Magnum
Ping. Yes. Flopping back n forth.
Fame mounts? At 4" do I really need to worry about that?
Keeping them horizontal.
I was thinking maybe of bent bars.
Track bar bracket can be lowered.
Merc225hp
NA
truck
gas
it stopped raining so i will go take some pix of some parts for you and post them up later. that should give you some info to work off of.
Jimmy68
Jimmy68
5.2L Magnum
Even better. So I can kinda have some guide lines. Most of which I'll make up as I go.
Just don't like the looks of stock arms. Be nice to see my own in there and move the diff to a better location. Seems too far back and I've got annoying bump steer.
Merc225hp
NA
truck
gas
Some hate the y style steering me I have no problems with it even with 7" lift. But ya pix later tattoo work first.
Jimmy68
Jimmy68
5.2L Magnum
What if one moved the lower arm to the top of the diff and made a new longer lower arm with a new frame mount?
That would assist in keeping things in place when doing a big lift. Curious.
Merc225hp
NA
truck
gas
Forgot about this thread. If you need specs ask.
joshhhh
