conversion kit for 04 1500 4x4?
Lone_Wolf
Illinois
2016 Ram 2500
hemi 6.4
is there a kit to convert the vacuum to a cable for the 04 ram 1500? my dads 4x4 quit working and we are thinking it maybe the cad.
L
Lone_Wolf
Illinois
2016 Ram 2500
hemi 6.4
vacuum that locks in the 4x4 convert it to cable
xb1230
Hobby Mechanic
South Shore of Montreal, QC, Canada
I guess what you should be looking for is changing the NP243 you have with a NP241 with a manual shifter and linkage.
But the NP243 does not have a vacuum lock, it is an electric motor instead of the manual shifter linkage.
JPT
NY
2015 Big Horn
its got the stick on the floor
The rams dont have a vacuum disconnected hub. The hubs are always locked (unibearings). Is that what you were asking?
Old 4wd vehicles, used to either have manual locking hubs (the switch in the middle of your wheels), or a vacuum disconnect so the front driveshaft wouldn't spin.
L
Lone_Wolf
Illinois
2016 Ram 2500
hemi 6.4
yeah i found out the 2nd gen used vacuum the 3rd doesnt. im still trying to figure out whats wrong with my dads truck put it in 4h we tried every way to engage it. light comes on and stays solid but the front wheel wont spin something sounds like its slipping its not loud. we even tries 4l does the same thing
JPT
NY
2015 Big Horn
Is there a way to manually engage 4hi by disconnecting the electronics? That would help you rule out a mechanical issue.
The only thing I can think of would be the electronic shifter is not working, or for some reason the chain split, and it is not giving power to the front. I have had Jeeps NP231 open to install a 2low kit, Slip Yoke Eliminator, and a teralow 4:1 front half. There really isnt much that can go wrong with these things.
L
Lone_Wolf
Illinois
2016 Ram 2500
hemi 6.4
its got the stick on the floor someone suggested maybe the linkage, my dad used the 4wd last year and worked fine
JPT
NY
2015 Big Horn
You really have to climb under it and check the linkage. If you feel it actually moving and locking into place, then it is working. Since they are in-line, it doesn't need to line up with a shift pattern.
L
Lone_Wolf
Illinois
2016 Ram 2500
hemi 6.4
it feels like it is weve got to get a new jack were gonna try jacking up the front end and turning the wheels
