Ramanski
Hey all,
Looking to tap into the RAM brain trust here.
I’ve got a 2022 DT RAM 1500 Laramie, 5.7 HEMI, about 30,000 km, truck originally came up from up north. I’ve been chasing a very faint coolant smell for a while now.
Quick background:
When I popped the hood recently, I noticed spots/stains on the hood insulation, mainly toward the front of the engine bay. They’re dry now, but clearly there.
So I’m wondering:
There are no active leaks that I can see, but the insulation definitely seems to hold odor, especially after heat cycles.
Before I go chasing ghosts or replacing parts unnecessarily:
Has anyone else seen hood liner staining + faint coolant smell on DT Rams?
Did it turn out to be nothing, or something worth addressing?
Appreciate any real-world experience, pics, or things I should double-check.
Thanks
Quick background:
- Radiator was replaced under warranty
- Cooling system pressure-tested
- No visible leaks
- No coolant loss
- No overheating
- Smell is much fainter now, but still noticeable occasionally
So I’m wondering:
- Could this just be road grime / salt / slush spray from winter driving up north that wicked its way up and stained the insulation?
- Or could it be residual coolant mist from the original radiator issue that stained the liner and is now just holding the smell?
- Anyone seen water pump weep hole residue show up like this?
- I highly doubt head gasket (no symptoms at all), but figured I’d mention it for completeness.
Thanks
