Cooling amp during the hot summer.
WilliamS
Tampa FL
I dont want to assume anything, but if its getting that hot regardless of time of year you are driving it too hard or your clipping like crazy.
AngryRams
AngryRams
Phoenix
It's 112 outside... Probably 130 in truck... Gain is around 45%
Sent from my SM-N950U using Tapatalk
WilliamS
Tampa FL
That doesn’t mean it’s no clipping or tuned right. My truck is black and in Florida and gets plenty hot but still amps run “cool”. Again not assuming but a clipping amp can run much hotter than it should
TomT
SoCal/OC
I’ve pushed my system hard while off roading in the desert and on Vegas runs, never had a problem. Then again I always have my air conditioning cranked.
AngryRams
AngryRams
Phoenix
**** sake it's 116 out
TomT
SoCal/OC
I’ve been in 120 before but that was in Havasu and there was a lot of beer and water involved.
adrianp89
Tampa Bay, FL
If it doesn’t shut off from protection then don’t bother with it. A lot of these new amps have the chassis as the heat sink instead of a dedicated one (makes them a lot smaller). Because of this they get hot just being turned on. It is nothing to worry about unless performance suffers.
AngryRams
AngryRams
Phoenix
Yeah, the new Kenwood xr models are TINY. And no performance issues.. was just wondering if I should find a way to set it on something other than carpet. My wife's uncle has a big shop at his house was going to look into making a small amp rack for the back wall of cab. And build a sealed enclosure for this w6.
autokraftgt
Hemi 6.1
Yea like mentioned above, as long as the amp isn't shutting down I wouldn't worry too much. I have had amps in the past that get hot to the touch but keep on truckin
DRkNESS
South Jersey
See above as my one amp you could fry an egg on, yet it never skipped a beat. But yes you may want to keep it away from the carpet if it’s that hot.
Nystagmus
NE Arkansas
2015 Longhorn CC
Back 25 years ago when I had a huge system with three amps, we used brushless fans like you see on PC towers. They worked great if you had them properly grounded so you didn’t get engine noise.
WilliamS
Tampa FL
My amps are mounted to back wall using rivetnuts, so plenty of heat dispersion if needed and they are out of the way.
AngryRams
AngryRams
Phoenix
I might also build a rack with two supports and just let it sit suspended over the storage cubby... Hmm
southalum
