Cooling issues
McG194
Palm Coast
I have a 18 Hemi Express with Quad Cab. Pretty much stock except for Carven cat back exhaust.
Last July I started overheating, discovered the radiator was leaking and replaced the radiator with an aftermarket unit, upper and lower hoses, thermostat, replaced the coolant and radiator cap.
A month ago it overheated again. The tech at work (Subaru dealership) said it looked like a bubble in the coolant so we flushed and burped it along with installing a 180 degree thermostat.
That fixed it for a month and it's doing it again. I pressure tested it and checked the coolant for combustion gasses and the system is air tight, it's not leaking into the heads. There is no oil in the coolant or coolant in the oil. When I'm driving the truck and it overheats, if I turn the heater on the temperature lowers so the heater core has been eliminated as a problem.
I have a warranty radiator here and am replacing it and I'm replacing the water pump as a good practice as the truck has 150K+ miles. The fan is turning so the fan clutch should be good but I'm also considering replacing that as well as another good practice. Is there anything I'm missing? Has anyone had a cooling system that gave them fits?
Before I realized that my radiator had a warranty I was going to buy the unit below as a higher capacity unit. I live in Florida and it's safe to say that I run the hell out of my truck. Anyone have any higher capacity recommendations?
Daw14
South Florida
You might have got a short lived thermostat, as it is sticking. There are a lot of counterfeit parts nowadays, but besides that , thermostats have become horrible lately for any longevity .
You clutch fan may be faulty, they are temperature controlled, they should start to have a rise in the resistance to turn as they get hotter.
If it spins easily when it’s hot it’s most likely bad and should be replaced.
I would recommend testing the t-stat in a pan on the stove, a candy thermometer works well, if you don’t have an infrared point and shoot.
M
McG194
Palm Coast
Thanks, I was putting a new thermostat in anyway but I was on the fence about the fan clutch. With 150K+ it can't hurt.
