Cooling system flushing?
roadstar30
Ok my 2017 6.4 Laramie is have heating problems driver side is cold the passenger side is warmer. So I thinking I Have the heater core problem so it needs to be flushed.
Has anybody had success with using the Prestone flushing additive as a solution ? Or does it need to be done only by disconnecting the heater hoses and back flushing ? Maybe I need to bring a blanket from now on!
mikeru
Super Moderator
Moderator Supporting Member
2020 Limited
Hemi 5.7L non-Etorque
I’ve use the Prestone flush one time, and had a heater core leak immediately after that lol. To be fair that was in a 20 year old car and it’s likely that there was at least a slight leak before the flush.
Flip-er
Raleigh, N.C
2013 Big Horn 4x4
I finally broke down and had my heater core replaced affter a few years of flushing it for same problem.
no heat drivers side heat on passenger side was good.
Flushing the core for me was just a band aid, worked for the cold season.
If it was me, and you plan on keeping the truck I would replace the heater core.
As i said I did, and I also had the evap and velve replaced while the dash was part,
heat now will run you out of cab
Grams
2024 & 2015
6.7 Cummins & 5.7 Hemi
With your heater selected “ON”..***…and blower on “high”…. place a hand down near the accelerator-pedal …to check for air-flow. Compare that air-flow to the area of the pax-side left foot-well.
They should be similar in air-flow.
If not… If the driver side has less flow….then it’s more likely the “blend door” issue instead of heater-core.
The blend door can be blocked by debris or mouse-nest or ? ? ? …and will need clearing.
Also, blend door actuators have been known to fail and reportedly are not difficult to exchange.
Post back with your results.
***= Select the ventilation-duct to blow in the “floor-heater-vents” position …rather than the dash-vents or defroster vents….for this test.
R
roadstar30
I have only 50k on the truck
R
roadstar30
Which blend door you talking about isn’t there four or five of them? I think I would like to know the temp coming out of the air ducts if the heater core is not blocked an fully functionable!
Dusty
Rochester, New York
There are only three doors directing air flow: Blend Door, Mode Door, Recirculate Door.
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, 18” wheels. Build Date: 3 June 2018. Now at 145903 miles.
