Cooper AT3 XLT
BrenttheMouse
Maine
Looking to get some Cooper AT3 XLT's soon. I've got a stock 2016 Ram 2500 and would like to go to 285/75/18. I was wondering if anyone knew if this size would rub on stock rims/suspension?
TBONE 2018
Tucson
That size should work fine, I am running 295x75x17 same tire on my 2018 2500. No problem.
BlackGold6.4
Thompson Manitoba Canada
Yup I had that same size and had no issues. One can fit up to 34" tires on stock rims and with a 4.5" offset rim ... but once you go to 35" tires they rub on the sway bar with stock rims and rub on the pinch weld with the offsets.
I like my coopers when we had them but have to say the Toyo AT3's are the best tire we ever had so if your still looking check them out.
retired
montana
that is a rare tire. I have never seen a 295/75-17. I bet you mean a 295/70-17 which considerably shorter than a 285/75-18
retired
montana
remember a 285/75-18 is a 35" it is a great size tall as a 35x12.5 but narrower..
B
BrenttheMouse
Maine
Isn't the 285/75 basically a 35" tire? So wouldn't this size rub?
AlexC2350
New Hampshire
Everything I’ve read and seen says 285/75/18 fit without issue. I was looking for that size tire a few weeks ago and couldn’t find it without a significant lead time and significant cost. I ended going with 295/70r18 in the coopers for 1400 out the door. They fit and look great. It’s the fourth set I’ve had and for the money they can’t be beat.
