0degC
My 1995 ram 1500 cranks but won’t start. Checked ASD relay seems fine and voltage there. Have no spark for sure no voltage at coil input, momentary some voltage with key on but no voltage when cranking. Replaced crank sensor and distributor pick up coil and still no start. Have 5v on signal wire from crank sensor and distributor sensor when key on and does not seem to go to 0 during cranking just some minor fluctuation in sensor voltage 4.8-5.2. Tried a second pcm (used, so how knows). Any ideas? Thanks
