Crank no start
thatred57
Massachusetts
2003 ram 1500 5.7 just replaced the starter. Truck will crank and putter but it won't turn over fully not sure what's wrong
jws123
nj
Well first off crank/turn over is the same exact thing it means the engine is spinning over. So as for it not starting did you check fuel pressure ect? what led up to this? it is a good idea to also scan for codes.
T
thatred57
Massachusetts
left it idling outside one day, and I come back outside and it wasn't running. go to start it again and all it would do is crank and sputter, but it wouldnt actually start. I have replaced the 02 sensors and I'm waiting on a new fuel pump and oil pressure sensor, and if worst comes to worst, a new MAP sensor
Daw14
South Florida
There is a really good search on this forum . Have you checked for codes ?
brixten
