kitz
would anybody be able to tell me the symptoms of a bad crank position sensor thank you
Well I got it running all fixed it was a weak fuel pump after all this timeBad crank sensor i remember cutting out surging and stalling from take off plus engine light and code. The cam sensor or coil pickup would run fine for 10 minutes after sitting 8 hours then stall with no fuel or spark.
Sent from my LG-M150 using Tapatalk
