Cranks but won't start. HELP
Royse0121
5.9l v8
My 2002 5.9 won't start!
Drove fine the day before the. The next morning I woke up and it cranks but won't turn over.
I can't hear the fuel pump and none of my gauges or stereo is working. I get the flashing lamp out signal as well as ABS fuel light and park brake. I just replaced the crank sensor and still nothing. Changed the battery and cleaned all grounds. I don't know what else to do. My obd reader says no link also
Gaboy02
5.9l
I also had the same thing on my 02 5.9l. It wound up being the ignition coil pack and the wire. Once those were changed ot started up no problem. Hope this helps
427invader
Air Force
Shippensburg, PA
My wife had the same problem in her 2001 Ram 2500 with the 5.9L. I changed the coil pack and wire and she was all good to go.
R
Royse0121
5.9l v8
Sweet. I'll be sure to give that a try. I'll post back when I'm finished thank you!
R
Royse0121
5.9l v8
That was it! Truck is on the road again. Thank you both. Almost bought an ecu
R
Royse0121
5.9l v8
So it worked only for a day.. There's something shorting out that ignition coil. Any suggestions?
R
Royse0121
5.9l v8
