Cruise control
Leeboy
Milan tn
Would bad wiring in the door harness that works locks make the Cruise control not set?
Karlsweg
SW Florida
Is abs light flashing? A speed sensor that’s bad will cause the cruise not to work
L
Leeboy
Milan tn
I have no ABS light no lights at all. And now I have Replaced the Accel and decel Button. Still not working
L
Leeboy
Milan tn
I’ve replaced the on and off switch. And the speed sensor in the transmission. Still no fix.
Karlsweg
SW Florida
I’m betting it is the abs sensor in the drivers side front hub.
L
Leeboy
Milan tn
Everything I’m reading says ABS light would be on is it unheard of for it not to be
L
Leeboy
Milan tn
What would the speed control fuse be listed under? there’s nothing in my panel that specifies speed control.
L
Leeboy
Milan tn
I did replace the front driver side axle maybe I had damaged the sensor I read it was on the front driver side but I have no light on dash.
BikerDash
Waterville, ME (USA)
5.9 Magnum
I have a similar issue. I would be able to turn the cruise control on, but it would not set, then would very soon turn off on it's own. Now, it almost is impossible to get it to turn on even, and when it does, within a second, it turns back off.
The issue started right after I had the transfer case and fuel pump replaced. They also took off the wheels to reset the bead on the tires to fix a slow leak.
