So I started to make a set of custom led pod brackets to use as fog lights. I see that one common bracket everyone uses but I don't like the look of the pods sitting a few inches behind the bumper cut out the way the stock fog light is setup. I decided to run an OPT7 18w 6 LED pod. My goal for these is to function like traditional fogs and face outward on an angle to illuminate the edges of the road where the headlight beams don't shine. I also wanted them to sit as close to flush as possible in the bumper cutout.
I started by making cardboard templates of the bumper opening and the LED pod, then transferring it over to a piece of 1/8" aluminum and cutting it out on the band saw. I could have cut the pod opening with a dremel but using the saw was easier and it took less than 10 minutes to weld it back together and grind the welds smooth.
Made it bolt up just like the stock fog light. I was happily surprised to find out the OPT7 pods came with 9006 connectors on them, so they were plug and play.
This is the spot beam pattern. I haven't aimed it yet, I want to bring it a little more to the right and a little more down. I'm going to be leveling on Bilsteins later this week and possibly a 3" body lift in the near future.
Tomorrow I'll finish welding up the other bracket and decide how to finish them. I'm thinking of spraying them with bedliner.
