Cut out loss performance
mimble
Perugia
Hi everybody
1 year ago, i install the electric cut out valve for have more loud sound from exhaust but i think that I loss engine power
It is possible?
Thanks
LeesEvoX
Houston, TX
Hemi 6.4l
Hi everybody
It is possible?
Thanks
It is possible you lost some low end torque. Dye to creating such a short path for the exhaust gases.
Sent from my SM-G950U using Tapatalk
RoadRamblerNJ
Mountain City, TN
392 Hemi
Not only possible but it is very likely you lost low RPM torque. With such a short exhaust, you are eliminating the back pressure the engine needs for best performance. Similar to running "open headers". Loud as **** but not as fast on the street. Track cars are tuned to that, your vehicle isn't.
mimble
mimble
Perugia
So, there is a solution to have loud sound and same performance?
LeesEvoX
Houston, TX
Hemi 6.4l
At least keep the length of piping the same. You will always lose some low end torque when removing mufflers
mimble
mimble
Perugia
Ok
Well, i will close the cutout when I go normally and open it when I want more sound
Thanks
WilliamS
Tampa FL
Just close it when you are driving normal for best torque, when you wanna be all noisy and such open it up! Im doing the same soon, curious if you used a kit
mimble
mimble
Perugia
I'm sorry
What do you mean?
Kit of what?
Jason G Slabaugh
Rossville Indiana
5.7l hemi
Just to clear things up NO vehicle needs backpressure to run properly. Back pressure is always bad when it comes to performance, the more exhaust you can push out the better it will breathe, yes you'll lose some low end torque because you just changed the power band where your power comes up higher on the rpm band. Factories will always tune a vehicle for low rpm and city driving where low end torque is more efficient than higher rpm power.
LeesEvoX
Houston, TX
Hemi 6.4l
This is true. But unless you have a race truck. You want SOME low end torque. Lol
RoadRamblerNJ
Mountain City, TN
392 Hemi
Pretty much what I wrote but thanks for clearing that up.
mimble
mimble
Perugia
Thanks to all
But there's nothing to do to have this sound and the same performance?
