abouttobeglue
- Sep 3, 2016
- 647
- 320
- 2016
- 5.7
Took my truck for another alignment today, shop recommended cutting the tie rods to get it decently within spec. Anyone done this?
So do you guys just cut the tie rod not the ends lol.. cut 1/4 inch off both ends of the rod alone? I got the 2/4 kit for my 4x4 with rear bags too
Ok I seen some sells the ends cut for when you lift. So I guess its the same deal lol.. thank youYou have to cut the ends,cutting the tie rods themselves isn't going to shorten anything except the tie rods themselves.
For 2/4 drop you do not need to cut the tie rod ends unless you are installing the Inez 4/6 drop kit.
the indicator is if you have plenty of thread meaning there is room for adjustment no cutting is required. This can be determined if the alignment is done or close to specs. The reason the tie rod end would need to be cut is if the rod had no more thread inward. In other words the outer tie rod end bottomed out on the inner tie rod.
So if you have plenty of thread on the rod (like oem) then you do not need to cut.
