Cylinder 2 misfire 2015 dodge ram 5.7 ssv
Dhollis15
Alabama
A few months back my truck started the ticking noise right after it hit 100,000 miles it was throwing the code cylinder 8 misfire on and off first I change all the spark plugs and coils after that I took it up to the dealer I got it from they decided that they would change the lifters and camshaft out for me that was about a month ago since I got it back it still slightly ticks and is now showing the code cylinder 1 misfire constantly sounds somewhat better but ticks mostly before I start driving it what should I do now?
Daw14
South Florida
Have you done anything with the exhaust manifolds ?
Use our search function to help familiarize your self with the cause of the tick. It’s not always the cam and lifters.
D
Dhollis15
Alabama
No I haven’t checked into the exhaust manifold maybe I should check that
Musky Mike
NC
So they changed the cam and lifters and misfire went from cyl 8 to cyl 1? Did they change all the lifters or just cyl 8 and reused the other lifters? Manifold leak will cause a tick, but I don't believe it will cause misfires.
Lysergic
Houston, TX
2012 & 2023
4.7L & 3.0L EcoD
I can't provide any suggestions about your tick issue, however with the misfire problem, I might give you something to check out.
I put up with a random misfire with cylinder 8 (passenger side rear on the 4.7L) on my 2012 Tradesman for years. No one could figure it out. I was talking to a former automotive tech that I work with about it and out of the blue he says to me "Check your injector wiring closely, unwrap it going back into the harness".
So I did. And found the problem in 30 seconds. Apparently at the factory, the worker charged with cutting the tape wrapping the injector wiring got a little too aggressive with his tool and nicked the insulation. Over the course of time, the slice got worse was causing an intermittent connection. The minute I unwrapped the tape covering, it broke clean.
Ordered a new injector connector and wired it up. No more misfire on Cylinder 8. :)
Here's a picture of the problem:
