Dash warning lights
John1957
Canada
Eco diesel
Hi I am looking for a full list of warning lights on my ram 1500 eco diesel I had a light come up and it insufficient power with a lightning bolt does anyone know what it means or can show me all the lists from Dodge?
turkeybird56
Central Texas
1) Go to URL and Download Diesel Supplement for 2018:
2) Go to URL and Download 2018 RAM Manual
ALL the info you are looking for be in these downloads unless U R looking for a service manual which are hard to find and usually cost $$$.
turkeybird56
Central Texas
— Electronic Throttle Control (ETC) Warning
Light
This warning light will illuminate to indicate a problem
with the Electronic Throttle Control (ETC) system. If a
problem is detected while the vehicle is running, the light
will either stay on or flash depending on the nature of the
problem. Cycle the ignition when the vehicle is safely and
completely stopped and the transmission is placed in the
PARK position. The light should turn off. If the light
remains on with the vehicle running, your vehicle will
usually be drivable; however, see an authorized dealer for
service as soon as possible.
NOTE: This light may turn on if the accelerator and brake
pedals are pressed at the same time.
If the light continues to flash when the vehicle is running,
immediate service is required and you may experience
reduced performance, an elevated/rough idle, or engine
stall and your vehicle may require towing. The light will
come on when the ignition is placed in the ON/RUN or
ACC/ON/RUN position and remain on briefly as a bulb
check. If the light does not come on during starting, have
the system checked by an authorized dealer.
joshhhh
