DashBoard Messages
rick_ca
Ontario Canada
5.7Hemi
Hello All this has happened to me 4 times now wondering if someone can shed some light on the issue, driving along any speed cruise could be on or of doesn't matter i get ABS/4x4/ and service brake system error codes all together. Then about 2 minuet's later they all disappear I read that battery could be issue so replaced original battery (2018) but it happened again, any recommendations as to where to start lookin would be appreciated
rick_ca
rick_ca
Ontario Canada
5.7Hemi
Sorry guys I put this in 4th Gen general discussion but was moved to audio electronics in 5th gen, mods please move to 4th gen thanks
RamCares
n/a
n/a
DM us with more details and your 17-character VIN. We'll look into it for you.
Chris,
Ram Cares
RamCares
n/a
n/a
Hello can you explain how sending vin# will tell me the issue thanks
We use the VIN to look for pre-existing documentation or STAR cases that may be associated with your vehicle specifically. They can act as instructions for routes of support. Also, using the VIN, we can check for potential warranties and other forms of support can may be available.
Chris,
Ram Cares
Tominator223
If it has the abs sensor on the top of the rear diff. That might be it. A wire got damaged or sensor starting to go bad. It (sensor) can also make speedo erratic . Mine was just popping abs & brake light on dash , then I noticed speedo didn’t work till I hit 10-15mph. Was the sensor. I got over 400,000 ml out of it . So no complaints.
rockyj69
