simplyal
I'm looking to wire a dashcam system that be a total of 3 cameras, Internal on windshield and two side mounted cameras on the exterior, video feed hub and an in cab monitor to view the video streams.
I will be running both constant and ground from the vehicle battery, into the cab and under the center console to an accessory panel switch.
The constant will have an inline fuse at the battery, my questions are,
- do I need a relay? When researching for light bars, etc, the recommendation is to have a relay.
- do I install a relay before the accessory switch or after the switch to the hub/cameras?
Does this look correct?
Lastly... if anyone know of a drop mount or bracket of some sort to mount external cameras to the underside of the mirrors, that would be awesomeness (last 2 photo ideas). Currently using clamp mounts.
