In my attempts to troubleshoot this ongoing error I found the following (all hubs continued to supply charge/power but no media connection to head unit):
- removed the head unit ensemble from the dash & disconnected all plugs from all components within for a full 24-hrs (reset/discharge period)
* top 12-V charging socket cable
* 8.40-in Display Screen's fakra cable
* UAV GPS Navigation Radio Module plugs - fakra/hvac/harness/sensor/control cables
(Error message reappeared upon reconnection of everything)
- removed center console to test each media hub's connection/wiring/pins and tested to see if error message appeared after each of the following:
* center console extension connectors for all media hubs/inverters plugs/led lights within the center console ensemble, disconnected all plugs & error message disappeared
* hub #1 usb/aux/usb-c ensemble under adjacent to center dash, disconnected all plugs & error message stayed so reconnected it
* hub #2 usb inside arm rest, disconnected all plugs & error message stayed so reconnected it
* hub #3 usb/aux/usb-c ensemble for rear seat connection, disconnected all plugs & error message stayed off; so reconnected it & error message re-appeared...
= pulled hub #3 out of the center consoles mounting spot for back seat connectivity/charging
= left the 2 plug connectors (grey & black only) hanging out the hub #3 hole
= replacement hub #3, will connect both plugs accordingly & then will push back into hole from the back seat.
The center console is back in its finished position and fully mounted. All other sockets are operational & the head unit fully functioning (CarPlay / all media selectivity / phone / bluetooth / Nav / etc.).
The new replacement is $120 - $220 online or dealer will install for $488+tax (USD)...I'm to cheap & enjoy learning / troubleshooting / helping other DIY'ers. I'll test the circuit board & see what components are compromised & their respective replacement costs (if any). I'm also looking for used anytime its reasonably sourced & priced...will follow-up with my solution.
