Uconnect Update - Device Not Supported USB
jp28173
Waxhaw, NC
I have a 2014 Express and am trying to update the Uconnect. I downloaded the update and extracted all the folders/files to the root folder of the USB drive exactly as outlined in the instructions. I've tried a few different USB flash drives but every time I plug it in it says Loading... then Device Not Supported. Any ideas??
MADDOG
Living in a Firepit
6.4L HEMI
Make sure your USB drive(s) are formatted in FAT32.
CanRebel
Toronto
What @MADDOG said above. You should also check if the USB is backwards compatible. Some claim to be, but usually are not. See if you can find an older one.
jp28173
jp28173
Waxhaw, NC
Thanks for the above. I did convert to FAT32 before I added the files for each or the USB keys.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
What size is the USB drive. I believe minimum is 8GB, I use a 32GB...
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
I was told to erase the thumb drive, zero bytes
Then FAT 32
etc. etc.
I failed & went to Best Buy & they failed, then i went to the Dodge dealer & they tried, then a tech came back from taking time off.
He took about 1/2 hour & wished me a good day
I paid & left.
I still don't know what he did
jp28173
jp28173
Waxhaw, NC
I think it’s a 3GB drive. The unzipped folders are only 1.16 GB so why would such a huge GB usb drive be required? I guess I could try to purchase a 32gb drive and try if that truly might be the issue?
RamInfo
Utah
5.7L HEMI
It may show onl 1.6GB used on the drive, but often firmware packages require a fair bit of extra space on the media. That gets used for backing up the existing firmware, expanding files, scratch space for writing to during the update, etc.
best,
DG
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
best,
DG
This. The files are compressed and need room to grow. I believe the older 8.4s minimum was 4GB to flash and newer ones are 8GB or 16GB. Can't remember which.
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Fyi... I've had good success with basic 16gb SanDisk usb2.0 drives at Walmart. Bought several.
