Commander 06
I have the diablo tune on 93 octane tune .. will I have to detune my truck to take it threw emission. My truck is a 2012 1500
I'm in MD so it is read threw obd2 port. I had a 87 tune on my jeep commander with hyper tech and that one passed.. I didn't know if it was different for the higher octane this is the first vehicle I've ran the 93 octane my Jeep and my F150 I only used 87 and 87 tow. My ram I have set for sport driving
I'm only on a preloaded tune with a few bolt ones. not a custom tune. all factory emission part are still functional
That's interesting because ARH has low restriction cats - they are not the same as stock. They have 200 cells and factory has 400 cells. I've seen users say you can smell the exhaust a bit, meaning they don't convert all the HC & CO.
I'm no expert but I'm theory is on location of the cat.
I have zero issues with smell or O2 codes infact passing emissions. My set up are aFe Long tubes. Some manufacturers put the cat right behind the header, others bend the y first then cat.
Again just my theory but the issue would be the bend in the y-pipe first then cat. Most OEM's mount the cat right after the stock manifold so it makes sense.![]()
