OMG, this vararam is a PITA to install. 2hrs later and it still wont fit. where am i supposed to move the relay thing attached to the horn? it says move in front of the horn in the instructions. does it just flop around up there? unless im missing something obvious... i moved the wire conduit running across in front and that sorta helps but the bracket/relay is in the way and even with it out of the way, i cant get the front of the whole unit to sit low enough. i had a far easier time (and less time spent) building my own CAI kit from ABS plastic tubes from home depot for a previous car. the **** poor instructions dont help. the horrid picture makes it look like the front flap sits over the main unit but the inserts seem to be designed such that it bolts under. if i cant get it done before dark, ill probably just send it back. catch can was a breeze, so that went well. 10min. done.
