- Jan 17, 2016
- 23,902
- 55,071
- 14 Sport
- 5.7
I think some of you guys are using dielectric grease for the wrong purposes.
Here's something you need to read.
I never put any inside a spark plug boot,i always put a smear of it on the base of the porcellin on the plug,so i do sort of disagree with the way they use it inside a plug boot
mgchemicals.com
Dielectric Grease on Spark Plugs
Dielectric grease is a simple compound of oil and silica filler that’s very hydrophobic and is excellent at sealing out moisture and preventing corrosion. The trick with using a dielectric grease is knowing where to apply it to seal the electrical contacts from moisture ingress and prevent...
