None of the manufacturers recommend additives, probably in part that there are so many out there. Unless you have a problem diagnosed by them. There were two EcoD owners (both in the Pennsylvania area) that had problems with asphaltenes. It occurs in common rail diesel injection systems. They form when diesel fuel is heated and put under high pressure, exactly what a HPFP does.
I run OptiLube XPD year round, it is the top diesel fuel additive available and completely safe for modern diesel engine/emissions. I use it primarily for the added added lubrication it adds since the the process to remove the sulfer from the fuel reduces diesel's natural lube.
https://opti-lube.com/diesel-fuel-improver/xpd-diesel-fuel-additives.html
Im not disagreeing with you on the premise that as a whole the diesel engine doesn't need it. Before this 20 model truck I've never ever used the stuff, so I'm not a believer, I hate spending the money. We're my opinion differs is based on data that shows our low standards for fuel lubrication in America, I feel like the cp4 needs it so to not wear scare and prematurely fail. I'm not willing to take the chance with out it, been to many studies and failures. As bad as I hate to spend the money on hot shot, what I would hate worse is battling back and forth with fca over a $17,000 bill because they claim fuel contamination. I'd rather pay a small amount for lube untill hopefully they get us cp3s back.People who swear by additives do so only because they BELIEVE they work. No need to waste your hard earned $$.
That's why there are millions upon millions of diesels out there running ZERO additives with no ill-effect.
Your diesel does not need any additive unless you will be using your truck in super cold temps. Then an anti-gel fuel additive is appropriate.
The amount of soot coming out of my tail pipe is almost none when I keep Diesel Kleen in the fuel and very obvious when I stop using it. It is not my imagination or what I believe but what I see.People who swear by additives do so only because they BELIEVE they work. No need to waste your hard earned $$.
Not sure why a 2 year old thread resurrected - doesn't seem to be a clear reason why.
It is interesting Cummins suddenly is recommending an additive, but the one they recommend didn't test well for lubricity. Perhaps it did for cleanliness or some other parameter.
Hotshot edt & lx4. All the testing data is online, anyone can look it up or I can post. Fuel in the u.s. sucks compared to other places.
I would like to see the warrenty claims per unit sold in these 2 states compared to Canada and the other StatesThat depends on what state you are in. California and Texas have much higher fuel standards and cetane requirements than the US federal requirements that the rest of the states use. The federal minimum cetane standard is 40 while Texas is 48 and California is 50. Minimum cetane number in most European countries is 40 and some countries have a minimum of 51. Texas and California also has better scar ratings than the federal standard than the states use as well.
Hot shot and a couple others additives (can`t remember the others off the top of my head) seem to be the go to additives....
