Dif swap on a lifted 18 1500.
Ohio5pt7
Ohio
Finally have funds together to to start my gear swap. Its going to cost more than normal I know just need to know what I'll need since mine is lifted I'm sure it'll change some stuff. I'm going 4.56 gears it's a 8 speed truck. So I know I'll be the pre 12 dif if I remember right and the axels what else. I'm sure the lift brackets may also be different?
Talk to Ian ,he just did his,and he'd be the guy to talk to.
2008 to 2012 Front diff swap 4.56 gears. | DODGE RAM FORUM - Dodge Truck Forums
DILLIGAF
Canadian Forces
Canada
Yup just go thru my thread all the info in in there. https://www.ramforum.com/threads/2008-to-2012-front-diff-swap-4-56-gears.173962/
Also here is another tread on it here. https://www.ramforum.com/threads/regearing-3-92-to-4-56-2014-ram1500-4wd.92619/
Only issues will be sourcing the IFS 8.0 shim kits. Ill be selling mine on here once I take the ones I need out of them.
I regret not just buying this kit instead of wasting my time trying to source everything individually.
https://www.motivegear.com/auto-parts-product/384994-456-ratio-ring-and-pinion-kit-for-8-front-inch-10-front-bolt-mgk-406/?crt_viaSearch=path:part%3Aring-and-pinion;year:2008;make:dodge;modelandsubmodel:ram+1500;enginesize:_ANY_
https://www.jegs.com/i/Motive-Gear/683/MGK-406/10002/-1
