DIY: 2013-2018/Classic OEM Foglight Wiring (& some 09-12 info)
Wesley0209
Ga
Hello I would like to purchase a fog light extension wiring harness for my 2017 ram 2500 tradesman. I have all of the other parts required that you posted on your write up. Thanks
Mpgrimm2
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Hello I would like to purchase a fog light jumper extension wiring harness for my 2017 ram 2500 tradesman. I have everything else purchased in your post for the mod. Thanks
Wes. I've been sick the last few weeks and haven't been taking new orders (large backlog). I will start back up sometime this Wednesday-Friday
I will send you a pm with my contact/ email info shortly (please remove yours from the prior post for your privacy from search engines/crawlers/spam bots.
M² Mods.
2018Beast57
NC
Hello I would like to purchase a fog light extension wiring harness for my 2018 Ram 2500 tradesman. I have all of the other parts required that you posted on yourwrite up.
Has anyone done a 6.4 swap yet??
Mpgrimm2
Mpgrimm2
SC
5.7L
Sent you a message with details/contact info
M² Mods.
kycruiser1
Tennessee
HEMI 5.7
I have a 2018 Ram 1500, already have the bumper with foglights installed, jumper harness is in place and headlight switch with foglight control installed. Is the jumper you provide all I need now to connect my foglights up? Thanks
Mpgrimm2
Mpgrimm2
SC
5.7L
That and getting the fogs enabled in the BCM at the dealer or via AlfaOBD.
Message sent with details.
M² Mods.
Kdawwg
Johnstown
I have a 2015 Ram 2500 Tradesman, I have installed foglights and jumper I would like to see about purchasing a extension wire of possible. How would i go about it?
Mpgrimm2
Mpgrimm2
SC
5.7L
Mpgrimm2
Mpgrimm2
SC
5.7L
Added info to post 15-16 & Foglight Dropout video link...
- Post 15-16: AlfaOBD & AE Tool Foglight Programming notes (vs Dealer Activation)
M² Mods.
jchristian
Hey Hey Guys new to this forum Just checking the Harness you sell is this the only Harness I need. I have a 2014 Ram 1500 I know I have to get the new Headlight switch but again Is this the only Harness I need Thanks for the info
Which Harness do I need to purchase and where do I get them Thanks again
Mpgrimm2
Mpgrimm2
SC
5.7L
Do you already have the Mopar jumper harness between the Foglights in the bumper that the dogs out into (with male 4 pin connector on driver side behind the headlight)?
See pictures in the op of both the Mopar jumper harness and our extension harness. (You need both)
M² Mods.
2ndA732
CA
Shout out to @Mpgrimm2 great instructions and clean wiring. My only revision is I did not 'gently insert the terminals'. Could just be my truck, but I had to push with all my might through my thumb and finger to get those terminals all the way in. The only hiccup for me.
Been waiting a long time to push that fog light button on my tradesman. Thanks again!
mopar_man72
PA
6.4 HEMI MDS
I have a '17 2500 Tradesmen that does not have factory fog lights. It does have the wiring down to the bumper with a dead end connector, and I am assuming these wires run back to the BCM. My question is there a way to tell the BCM to turn on the fog lamps with out buying a new head light switch?
Mpgrimm2
Mpgrimm2
SC
5.7L
DIY: Add 2013-2018 OEM Foglight Wiring.
** AlfaOBD.
(for activating factory features yourself. See docs linked in OP)
M² Mods.
mopar_man72
PA
6.4 HEMI MDS
I'll have to post a picture of it tomorrow. The only other thing it might be is for front parking sensors.
1500ram12
5.9L Cummins
Here is the front module under the fuse box
Here is the connector where the fog light jumper harness connects to. Should be near the drivers headlights/fender well if equipped.
Here is what the fog light bulb connector looks like
Here is probably what you are found
2018 Ram 2500 6.4L Hemi Tradesman
mopar_man72
PA
6.4 HEMI MDS
What I have must be the park assist wiring. Also it looks like there is no way around the correct headlight switch, unless I knew the correct resistor to add to the circuit board in mine. I've been looking on e-bay for switches. Would a 09-12 switch work or do I need to pay the big bucks for a 13-18?
1500ram12
5.9L Cummins
A 09-12 should work. The connector and wiring diagrams are the same between 09-18
Mpgrimm2
Mpgrimm2
SC
5.7L
Please keep in mind the 09-12 trucks may have similar wiring as the 13-18/19 classic but the various modules that communicate on the bus may be different/have different node addresses etc. Your best bet to avoid spending more money is to get the correct part number switch (new or used).
*Also* ... This thread is in the 5th gen section/for the 5th gen trucks and these posts should be in either my 4th gen Foglight thread or in a new thread in the 4th gen section.
M² Mods.
ChloeBrooks
