DIY check tire size setting?
Teligence
Is there a way to check what tire size is programmed into the PCM? I bought mine used and the tires aren't original size, so I wanted so see how much of a variance there is to determine mileage/speed accuracy. It may be that it's already been adjusted to my current tire size, but I'd like to verify...
usaf2006
North Carolina
Depends on what it came with from the factory . Your local dealer may tell you for free, but I doubt it.
verify your speed against a GPS, the speedometer should read within about 1 mph. Probably best to check it on the freeway at 70 mph
justin13703
MD
It won't be off much. With my 35s, at 70 mph the speedo is only off by 3-4mph. Best bet is to check it with a gps. There is no way to know for sure what is programmed into the computer unless you program it yourself with a tuner.
HemiLonestar
Navy Badge Coast Guard
MD
DRB for absolute verification of what the pinion factor is. If you're in MD I can check it for you.
