Kernal Clink
So if I level my 2wd truck with 2.5" spacers do I need to change the UCAs as well? I know it will need an alignment but wasn't sure about the upper ball joint angle.
Well my truck is a pavement princess so I won't ever know the difference. I just don't want to wear out the upper ball joints and be walking home.You're removing 2.5 inches of suspension travel.
If you use aftermarket uca's they'll give you that suspension travel back.
