Dodge Ram 2016 Front Lights
IGIRACER
CT
Hi Guys
I have Dodge Ram 2016 5.7
I want to change my front bulbs lights to something better and more bright,
any suggestions ?
Thank you.
guarj17
Long Island, NY
I just ordered these LED's:
Low Beam: H11 LED Headlight Conversion Kit
Read no reviews on them but go fed up with trying to pick a kit I just ordered it and I'm hoping for the best. I will be putting them in Thursday so I will let you know how they work out if you want to wait until then.
I also have a 2016 5.7 Big Horn. I have the H11 bulbs for low beams.
swine
NE Indiana
It's hard to tell from you pic, but it looks like you have quads. If that's the case I'd suggest running H11 instead of the stock H9 bulbs. The H9 is quite a bit brighter without being blinding. You just need to trim some tabs off the bulb base to get them to fit. Google H11 to H9 conversion.
I don't recommend the LED or HID solution. The LED's are whiter, but in my experience don't throw the light as far as the standard halogen bulbs. It'll seem like they're brighter because the light is so white, but that's not the case. HID's in the quad reflectors are just blinding to opposing traffic. Don't do it.
If you really want to improve your lighting upgrade to projector lights. TYC makes a good alternative to the OEM projectors and they run about $450 a pair. You'd also need a conversion harness at about $135. If that doesn't do the trick you can run HID's in those without blinding traffic.
IGIRACER
IGIRACER
CT
Thank you for reply.
Do i need any specific kit for it ? transform anything or just plug in?
Can you please specify a model number if you can i would very appreciated it!
thank you
IGIRACER
IGIRACER
CT
Thats great ill wait let me know.
tnx
Teknoracer
I just ordered some led kits for my quad low beams and fogs from Headlightrevolution.com today. Should have em in by the weekend and ill post my results/opinion
guarj17
Long Island, NY
Read no reviews on them but got fed up with trying to pick a kit I just ordered it and I'm hoping for the best. I will be putting them in Thursday so I will let you know how they work out if you want to wait until then.
I installed the lights I previous linked ^ and they look great so far. Only issue with install is the nipple on the clip that holds the aftermarket clip to the factory clip was on the wrong side. Electrical taped it for now and sent them an e-mail that they responded to within minutes confirming the issue. I will advise of the resolve. I will take light throw pictures tonight to give you an idea of the light they put out but I have this before and after pic for now:
