Dongar Mirror tap for dash cam Found answer
Mlarv5
Crossville TN
I have used these Dongar mirror taps for my dash cams in pretty everything I have had for awhile now. I have a 2025 Ram Big Horn. I contacted Dongar and they said this one would work. You unplug the wore harness from the back of the mirror, plug it into the Dongar cable, then plug the other side of the Dongar cable into the mirror. It has a USB port output also. Mirror Tap. My question is. It came with a little pry bar to remove the cover behind the rearview mirror. Anybody done this? I don't want to mess up and break clips etc. Thanks
