Ryan Stutz
I need some new doors for my 2008 crew cab 1500 and a local yard has doors for a 2005 3500 crew cab. Will they work with my 2008 and if so will the 2008 interior door panels fit on the 2005 doors?
That was a question about mixing single and quad cab doors. This one is quad to quad, but it's early 3G to later 3G. Yes the panels should fit BUT there was a variation in body lines you will want to check/do a comparison.Thought I saw this question elsewhere. The single cab doors are bigger.
My bad, I had seen that other question and the words all jumbled together. Thanks for catching this for me.That was a question about mixing single and quad cab doors. This one is quad to quad, but it's early 3G to later 3G. Yes the panels should fit BUT there was a variation in body lines you will want to check/do a comparison.
