Door Leak
Chucky44
HEMI 5.7L
Hey,
I have noticed that the carpet next to the door sill of the driver is wet a little bit. I have been trying to figure out where it's coming from. I know it's the not the third brake light since I replaced the seal around it and tested out the satellite for leaks and that one is fine as well. It seems to be coming from the either the window or the seal around the door. I look at the seal around the door itself and the seal around the truck and it looks fine. The only thing I noticed was the seal and the bottom of the door (bottom of the speaker) was wet, so i'm thinking it's coming from there. Could it be coming down from the window and the water is running down there. I looked at the drain holes in the door and they look free, the only thing might be the grease from the undercoating that they could put in the doors. Any thoughts?
