Door lock part #?
719c6
Anyone know the actual part number for the door lock actuator for a 2011 Ram Crew driver's rear?
14hemiexpress
6.4l
Interesting. Mine in my 10 is giving me trouble sometimes locks sometimes doesnt, sometimes it won't unlock.
RamCares
n/a
n/a
If you DM me your VIN, I can look to see if I can locate the accurate part number. You may also contact your local dealer for assistance. Thanks! – Kevin T, Social Connect Team
BlownGP
Houston/Baton Rouge
Anybody ever find the part number?
My passenger rear won't lock.
14hemiexpress
6.4l
4589650AB, 4589650AC, 4589650AD
Double check those but I think that's what your looking for. I did the rear driver side over a year ago. It's the whole unit you have to replace the latch and all. Not a hard job if you have done it before but does require some patience. I had to remove the window from the track (i just securely taped it up I didn't actually remove it from the truck) to pull the inner door panel out to gain access to get the latch assembly out.
BlownGP
Houston/Baton Rouge
Thanks man.
Good info. Probably will have some more questions when I decide to do this.
So this is all I need?
https://www.amazon.com/Dorman-931-093-Door-Actuator-Motor/dp/B01ID3QXRO
14hemiexpress
6.4l
Thanks man.
Yeah its plug and play it's just basic remove and replace. All the door rods are easy if I remember right there no way to mix them up. The worst part was just figuring out how to get to it. I finally found a break down on another forum somewhere but you gotta pull the inner panel out there is no way around that I spent more time trying to get to it without pulling it than it took to pull the inner panel and to do so you gotta remove the glass from the track. Also I think rockauto has them cheaper you may want to check there when you are ready.
