Door mirror upgrade help
Solej
Is there such a thing as a side view door mirror with heat, turn signals and puddle lights that are not flip up tow mirrors? Preferably gloss black.
Next question is, do you need anything besides just bolt on mirrors? Thanks for the help ahead of time.
Sent from my 0PJA2 using Tapatalk
fdnj48
Central NJ
My 15 Big Horn came with heated, turn signal and puddle lights and they are not tow mirrors. They're just not gloss black. They're the more flat textured black. My guess if you're looking for gloss black Is that'd you'd need to go with a Sport model mirror. Not sure what you would need to install them tho
Ricks Ram
If you already have the tow mirrors with the blinker puddle lights it's a simple remove and replace. If your truck doesn't have the blinker puddle light mirrors you will need to have the dealer add the LEB and LEC codes to your truck in order for them to work. There are gloss black mirrors available that come on the Sport model. They are alot harder to find used and are more expensive. I would check Car-Part.com and e bay for a used set or just buy the regular mirror and buy a black cover for it that they sell. If you truck is a 13 or newer it's important that you get the correct mirrors for that year as the temperature sensor is it your drivers side mirror.
