Door shut but car senses open door
Degu67
Hello,
I have a problem with my 2014 Ram 1500 Quadcab Sport: The passenger door is closed but the car senses an open door. Have already changed its door lock (where the sensor is) but no success. My truck has 8000 miles on it, so I don't think that there are already squeezed or bended wirings.
Has anybody had the same problem and found a solution?
Thank you
Degu
Hootbro
U.S. Army Veteran
Army
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
Wiring or door control module. Need a schematic, meter and someone with some troubleshooting skills if you do not want to shotgun parts at it until fixed.
With a schematic, you can jumper the contact points on the harness at the door lock switch and work back.
Slick61
try spraying your door latches with a little WD-40...
Ricks Ram
I would take it to the dealer under your warranty and have them figure it out.
Bettula
